P-90's with adjustable poles VS non-adjustable.....
PorkyPrimeCut
Post by PorkyPrimeCut » Thu Dec 13, 2007 7:52 am
What difference does it really make??
Is it only an issue if you have a really low action or are there other benefits in having adjustable poles??
Equally, what other downsides are there in having fixed poles??
....and....
Do ES-335 tailpieces (with the raised diamond) fit ES-125's??
Re: P-90's with adjustable poles VS non-adjustable.....
Post by Stereordinary » Thu Dec 13, 2007 9:06 am
I don't think I've ever seen a P-90 with non-adjustable pole pieces.  Where ever did you see that, kind sir?
PorkyPrimeCut
Post by PorkyPrimeCut » Thu Dec 13, 2007 9:19 am
Oh??  :-[
Maybe I'm being a dumb-ass. I'm looking at ES-125's & I think I made a false assumption.
For some reason I thought the 1940's ones had fixed poles, changing later on to adjustable ones.
I think I may well be totally wrong now that I think about it!!
Ah well. Live & learn.
Post by Stereordinary » Thu Dec 13, 2007 9:43 am
Okay, I couldn't get this out of my head, so I did some research.
There was a P-90 made for the ES-125, with non-adjustable AlNiCo 5 rod magnets directly in the regular P-90 coil.  And in 1949, a new pickup was made for acoustic archtops, with a wider coil, fewer turns and rod magnets, called the McCarty model.
k o y l
Post by k o y l » Thu Dec 13, 2007 9:45 am
stereordinary wrote: I don't think I've ever seen a P-90 with non-adjustable pole pieces.  Where ever did you see that, kind sir?
On my OTM Jazzmaster ...  :P
PorkyPrimeCut
Post by PorkyPrimeCut » Thu Dec 13, 2007 9:48 am
stereordinary wrote: Okay, I couldn't get this out of my head, so I did some research.
Oh. So I was accidentally right?!?  ???
berlinbetty
Post by berlinbetty » Thu Dec 13, 2007 9:54 am
  I was just reading somewere (was it here?  I can't even keep track anymore... :() that the only reason humbuckers had adjustable poles was because P-90s had them and Gibson thought it would be more of a selling point.  I recently found out through a humbucker mod I discovered where you can switch between north/full/south that the stud side has a stronger (better?) sound than the adjustable side.  Ever since I discovered that I flip my humbuckers around to have the stud side nearest the bridge/neck what have you and they sound GREAT when split!
  With all this in mind, I imagine that a P-90 with studs would be better.  And Curtis Novak just happens to make that very pickup for a Jazzmaster!  Whataya think of that?!?
One more guitar, then I'll practice!
Orang Goreng
Post by Orang Goreng » Thu Dec 13, 2007 9:54 am
PorkyPrimeCut wrote: or are there other benefits in having adjustable poles??
Adjustable string volume. With adjustable pole pieces, you can easily set up your guitar so that each string will sound equally loud, which can be quite a problem with non-adjustable pieces. Downside may be that adjustable pole pieces may (i think) have more microphony problems associated with them, as they can vibrate more easily. Or at least that's what I expect.
Post by Stereordinary » Thu Dec 13, 2007 10:06 am
PorkyPrimeCut wrote:Oh. So I was accidentally right?!?  ???
Yes.  And I was accidentally wrong.  :D
tsalwel
Post by tsalwel » Thu Dec 13, 2007 10:08 am
adjustable poles
how does it look like....
  d
music ALLways
music  IS my motor
PorkyPrimeCut
Post by PorkyPrimeCut » Thu Dec 13, 2007 10:33 am
tsalwel wrote: ??? ??? :-[
adjustable poles
   d
They have a slotted top to fit a screwdriver.
.....or were you cracking a dirty joke??
tsalwel
Post by tsalwel » Thu Dec 13, 2007 11:26 am
adjustable poles
   d
something like this ?              Image
jeeeez ........
i have a gib de luxe with this since ...1977
o well
so they are adjustable ?        in hight or what ?
as for the dirty joke  ;D          Image  pork you started it
;D
  d
music ALLways
music  IS my motor
PorkyPrimeCut
Post by PorkyPrimeCut » Thu Dec 13, 2007 4:29 pm
tsalwel wrote: ....so they are adjustable ?        in hight or what ?.....
Yup. In height. Closer or further away from the strings.....It regulates each strings volume apparently (thanks orang).
As for the dirty joke....anything in English using the words "pole" & "screw" is open to standard joke material.  ::)
Thankfully this time I was mistaken.....
...by the way. Whats with the red / blue stick business??  ???
tsalwel
Post by tsalwel » Fri Dec 14, 2007 9:46 am
google    adjustable poles.....
??? gives you that  ;D looks like they "are " adjustable
and they look like euh          poles                            ;D
you just screw ( ay )  ;)                                      up or down ?  :-[
  d
music ALLways
music  IS my motor
