Tummy Cut Dimensions
- bdf83
This might be a stupid question but I can't the dimensions and exact positions anywhere (and I HAVE looked) so could anyone with 5 minutes and some callipers tell me the dimensions of the tummy cut on their Jazzmaster?
Depth relative to body thickness/Width towards the centre of the guitar/overall length of the contour/ relative position from the upper horn. Any of these would be helpful.
Its not on any diagrams I've seen and have been wondering how you go about getting it right. Surely it can't just be "keep going until it feels right"?
I've got a couple of offcuts and have tried a couple of different methods before Im going to do it on the one-piece body I've got but need the dimensions first. Ive gone through the "marking it out, sawing notches in and chiselling" technique but I'm worried I'd saw too deep and have a nightmare trying to sand it out. The last one I did with a rasp and a spoke shave and then sanded it smooth(ish) which I think is going to give me the best results but everything I'm learning is from on here and youtube tutorials.
Any help would be appreciated.
Thanks
Thanks
- empyrean
Re: Tummy Cut Dimensions
According to this image it seems to be about 20.5mm deep, 264.9mm long. It's either that or 29.5mm deep, it's hard to make out. It starts 3" from the horn.
http://ultimate-guitar-online.ultimate- ... master.jpg" onclick="window.open(this.href);return false;
- inkeye
Is it the same for a Jaguar? I tried searching that site for a similar image.
- empyrean
Looks like it: http://ultimate-guitar-online.ultimate- ... jaguar.jpg" onclick="window.open(this.href);return false;inkeye wrote:Is it the same for a Jaguar? I tried searching that site for a similar image.
- saxjag
I believe the Fender Custom Shop uses one's actual tummy as a template.
I've just done something similar to an unfinished JM body (wish I had those drawings ). I used an angle grinder with a sanding disk. If you use a reasonably fine grade disk you can do it nice and gently. It does the curve quite well, but practice first on an off cut is probably a good idea.
- bdf83
Awesome, thanks for those, they'll definitely help.
Cheers
Ed
Cheers
Ed
- ludobag1
for me careful with this plans not accurate to my taste
look the deep of pups for exemple , the distance between tuners ect ....
it is only an version of jazzmaster not the real deal
- bdf83
its cool, its more for a guide than anything else. I took the routing depths from another thread in here from a '62 so it should be reliable enough for what I need.
- inkeye
Thanks for checking that out. I appreciate it.
- rantbot
