Jazzmaster pickup: neck or bridge?
- seasick croc
Here are two images of the same 1966 Jazzmaster pickup. Is there a way to tell if it was originally in the neck or bridge position?
- NoFi
Re: Jazzmaster pickup: neck or bridge?
If the pickups are supposed to be Reverse wound/reverse polarity on 66 jazzmasters, you can probably tell which is which by puting a compass vertically above the pickups.
It will allow you to see which one has the magnets north up or south up.
Then of course you would have to know if neck pickups in 66 jazzmasters are supposed to be North up or south up...
But i dont think you can tell from the pictures only (i think it's i love sharin foo's pickup, a board member here, maybe he will know).
- JazzBlaster
Put the face of the pickup to the face of a known bride pup. If it's a neck the oposite poles will atract.
David
David
- Orang Goreng
Or use a compass: http://www.offsetguitars.com/forums/vie ... 715#p16715
- mezcalhead
- Admin
If the wiring is right then that's a neck pickup.
- i love sharin foo
I was the one who sold that on eBayseasick croc wrote: Here are two images of the same 1966 Jazzmaster pickup. Is there a way to tell if it was originally in the neck or bridge position?
Justin
