Coodercaster Build UPDATE PG 6, AUDIO PG 8
- hpr_hpr
Re: Coodercaster Build
Assuming we are talking about the neck pickup (if it's the bridge just interchange bridge & neck below).
There is no point in running a separate ground wire UNLESS you isolate the coil from the cover . . .
If you ground the cover separately AND 'invert the phase' without isolating the coil you ground both ends = no signal.
Current (colors for illustration only):
black = coil start + cover -> connect to GND
white = coil end -> connect to switch
if you add a separate ground wire for the cover and 'invert phase' you end up with:
white = coil end -> connect to GND
black = coil start + cover -> connect to switch
bare (from the cover) -> connect to GND
As you can see black now has a direct path to GND (via the cover) and white is directly connected to GND = both ends of the coil connected to GND = no signal to switch . . . in addition, if you wired it like this and you set the PU switch to BOTH the bridge would be grounded at both ends as well = dead guitar . . . the only signal would be with the switch in the bridge position which should work correctly.
- StevenO
I'm going to try and do some experimentation with the wiring some time this weekend, if I can. I really want both pickups in this guitar, so hopefully I can get around the phase issue. Worst case scenario, I either just have one pickup in this guitar, or I have just a two-position switch.
What I really don't want to do, is have to spend much more money. I have all the pots and switches already, so it's just a matter of getting a guard made and figuring out the pickup configuration...
I still want some fancy knobs, though!
![Glare :-/](./images/smilies/glare.gif)
![Smiley :)](./images/smilies/smiley.gif)
- Fiddy
I have an old pickup that reads 4.2k that wont have those issues...
Not sure if you're interested... Free, if you want it...
![Image](http://i.imgur.com/pvQhWRB.jpg)
![Image](http://i.imgur.com/3n47rC9.jpg)
- StevenO
:0
I'll take it, if that's the case. Pack it together with the knobs I'm buying off of you?
- Fiddy
Sure, ill save it for you. I did extend the leads too btw.
Err, what knobs tho?
- StevenO
Oh geez. I misread who posted that. I thought you were Contiki/Chris. ![Wacko :wacko:](./images/smilies/wacko.gif)
And thank you! That'd be great. Always curious about weirdo pickups.![Smiley :)](./images/smilies/smiley.gif)
- StevenO
Is there such thing as a 2 position tele-style switch? Or a 2-position rotary switch?
If all else fails, maybe I could just a jag-style 2-way switch to go back and forth between the neck and bridge pickups?
- hpr_hpr
Not in the form of a tele switch that I know of. They do exist for rotary switches e.g. https://www.digikey.com/product-detail/ ... ND/1046759 . . . .
- DrQuasar
You could use an on on toggle switch as well.
- StevenO
I might have to... I was thinking about using a rotary switch, so I could just fit a knob over top of it to turn the switch. BUT, probably not the best solution for quick pickup setting changing.
I maaaay put this guitar on hold for the time being. I have no clue what to do with it as far as pickups... I'll keep mulling it over, though. No real rush.
- StevenO
And just in case anyone thought I was someone who stuck to my guns... I put the HersheyBar pickup back in the neck position of the guitar and
So...![Whistling :whistle:](./images/smilies/whistling.gif)
![Kiss :-*](./images/smilies/kiss.gif)
So...
- StevenO
Good idea? Bad idea?
- Ursa Minor
Good idea - but won't you have the same issues as before? You'll have to check polarity and compare with neck pickup.
- Ursa Minor
You could also just put the one pickup in the middle. ![Tongue :P](./images/smilies/tongue.gif)
- StevenO
Well, at least with the bridge pickup, I could switch the leads and because the casing isn't metal it won't have the same issue as the metal covered Silvertone/Harmony pickups IF IM THINKING CORRECTLY.kosmonautmayhem wrote: ↑Thu Apr 19, 2018 4:19 amGood idea - but won't you have the same issues as before? You'll have to check polarity and compare with neck pickup.
As for putting it in the middle, I actually have the pickup right in between where the Neck and Middle pickups would be on a Strat. It's the Cooder position, really.
![Wink ;)](./images/smilies/wink.gif)
